Torsion bar adjustment
Old Jul 7, 2009 | 07:05 PM
SPICOLIE203's Avatar
I have a 65 belvedere II I just recently adjusted the torsion bars to get a nice firm ride up front and swapped out for new leafs in the back but I would like to lower the front just a little without sacraficing ride quality.
Does anyone know how to adjust the torsion bars down and still maintain a firmer ride up front?
Thanks
Luke
Old Jul 8, 2009 | 05:59 PM
theomahamoparguy's Avatar
Other than the torsion adjust the only other option would be the lowering spindles. (someone just came out with some new lowering spindles that are one piece, just cant remember who, will try to find and post)
Old Jul 9, 2009 | 07:39 PM
Mopar_71's Avatar
Hi Spicolie203!!
What size motor do you have and what size torsion bars are they?
Do you have a stock setup?
If you lower the ride height using the bolts in the lower control arm, it will firm up your rebound rate and lower your front end. But, if your ball joints, tie rod ends, shocks and pitman arm are worn you may run the risk of putting a lot of stress on your suspension components that may fail.
To lower your ride height, raise the front of your car with both wheels off the ground. SUPPORT your car with jack stands.
Using a 3/4 inch socket and a 1/2 drive, loosen the bolts located in your lower control arm the same amount of turns. Tighten to raise it.
Just remember that you might have to adjust your headlights if you go to an extreme difference in height.
Enjoy!
Mopar_71
luke
Feb 5, 2011 06:42 AM
raindance654
Dec 18, 2009 02:02 AM
raindance654
Oct 15, 2009 02:43 AM
AirBorne
Apr 19, 2008 04:02 AM
krsboz
Sep 23, 2007 09:10 PM
