transmission questions?
Old Jan 23, 2009 | 03:16 PM
pipdog69's Avatar
Junior Member
How can you tell if you have a fwd or reverse valve body on a 727 torqueflite tranny. I want to put a floor shifter in my plymouth but I need to specify if it is a fwd or rev valve body. I do not know a whole lot about transmissions and would like to know what the differences are.
Old Jan 23, 2009 | 04:53 PM
Commando's Avatar
I assume the company who makes the shifter is asking you this? Is that the only difference between the two options?
Old Jan 23, 2009 | 05:27 PM
Crazy4Carz.Com's Avatar
Standard valve body: P-R-N-D-2-1
Reverse body (what is in my Dart): P-R-N-1-2-D
This way when you shift you are shifting away from park and reverse and can't Oops your way into neutral. Also when this is the case there is often a trans brake and a manual valve body. With a manual it is just like it sounds, you have to shift manualy all the time just no clutch. If yours is not a raced car in its past or presently, or if you have driven this car without any surprises, it is not reverse.
Old Jan 24, 2009 | 03:34 AM
pipdog69's Avatar
Junior Member
thank's man, it makes a lot more sense to me now.
BTYM
Mar 19, 2014 02:09 AM
MoparMan76
Jan 14, 2011 01:31 PM
moparkid#09
Feb 24, 2010 04:40 PM
67gtxclone
Jan 7, 2010 05:06 PM
crashcaptn
Jan 14, 2007 04:46 PM
