What To Check On 2010 Ram 3500 Exiting MOPAR Warranty?
Hello,
I have a 2010 Ram 3500 Crew Cab Laramie Long Bed 6.7L Diesel that is coming up on 180,000 miles. I have an extended MOPAR warranty which will be running out at 181,000 and don't believe I will be able to get a new warranty due to the mileage. While this has been a pretty solid truck, I have had a number of issues as it has aged so am a little concerned about running into a major, very expensive, issue shortly after the warranty expires. I am hoping folks here can offer suggestions of things I should be sure to check before the expiration so I can be moderately comfortable this truck will keep working for at least a little longer. If you need any additional info from me do not hesitate to let me know.
Thanks in advance!
Chris
Thanks in advance!
Chris
I know there are often things not obvious until you look close or open some parts up and am hopeful I can give a little direction to look at these. Even if I get a new warranty, it would be to my advantage to be aware of any upcoming likely issues.
