What line flare is this?
Old Jan 18, 2023 | 06:11 PM
Koslaw's Avatar
I have a 1991 new yorker and I am replacing the steering rack transfer lines. (The ones that run from one side of the rack to the other). I need to make new lines and the flare that this seems to use looks like a bubble flare that got flattened, or an incomplete inverted flare. Does anyone know if it's supposed to be a bubble flare? All the fitting ends and flares look the same.
Old Jan 20, 2023 | 07:24 AM
I have no clue...
Old Jan 21, 2023 | 07:33 PM
dodgem880's Avatar
Looking at power steering hoses on rockauto it looks like they use an oring. Maybe the fitting you have pictured is a damaged one with the tip broke off that holds the oring? Maybe check the rack for the oring and short tube piece?
edit: never mind missed the part about all the fittings being the same
Drummer4life55
Nov 16, 2018 05:27 PM
scrapmetal
Sep 9, 2011 07:19 AM
rexus31
Jan 14, 2011 07:41 PM
rexus31
Oct 26, 2009 07:39 AM
