when i floor it.....
Old May 5, 2009 | 12:05 PM
timing could be off a touch.
Old May 5, 2009 | 12:06 PM
scotts74birds's Avatar
From a stop or from a roll?
Old May 5, 2009 | 12:41 PM
I'd start with tims suggestion, cause its easy and cheap, like me! My suggestion, if its from a roll only, is that you accelerator pump shot may need a longer duration.
Old May 5, 2009 | 01:02 PM
We're not talking about your civic are we? If not what car and motor?
Old May 5, 2009 | 01:39 PM
johnthegoalie's Avatar
thinkin with me dipstick
dont know if they are still around, look up pro-dyno, they had a shop in tempe a few years ago. they will tune your motor to its peak, and dyno it. carburetors can be finnicky, big difference especially when you are coming from a fuel injected computer controlled car
Old May 5, 2009 | 02:03 PM
you'll need a timing light to do the timing
Old May 5, 2009 | 03:06 PM
beep1969's Avatar
Junior Member
my roadrunner id the same thing when i first bought it my points were fried, you can try that
Old May 5, 2009 | 03:27 PM
if it still has points, you might want to invest in a mopar performance electronic distributor setup
Old May 5, 2009 | 03:48 PM
Commando's Avatar
Do you have headers?
Does it stall if it sits for awhile, or after sitting for awhile running and you hit the gas it stall?
Old May 7, 2009 | 05:35 PM
points were an OLD way of charging the coil to create a spark
Old May 8, 2009 | 05:57 PM
Commando's Avatar
Has it ever stalled?
I had a problem with vapor lock as my fuel line ran over the headers before the carb. When hot the car would sputter when I would hit the gas, bog down when driving, or stall when it was hot and I let it sit running. Just a thought.
Is the fuel line so hot to the touch it burns? I rerouted the line and I have no issues mentioned above.
bevelhead
Jan 23, 2011 10:42 PM
crash dummy
Sep 10, 2008 07:23 AM
miradaman
Jul 24, 2008 05:59 PM
CoryOriho
May 17, 2008 12:43 AM
rubadub
Nov 10, 2007 12:34 AM
