Wiring an engine to test run
Old Sep 29, 2009 | 08:18 AM
Bossta's Avatar
Junior Member
Please Help....I installed a 1966 383 in my sons Studebaker. Now, I want to test run the motor...I ran a positive battery cable to the starter, the black wire from distributor to the negative side of the coil and a positive lead from the battery to the positive side of the coil. The engine & battery are grounded to the frame. Still no spark....what am I missing?
Old Sep 29, 2009 | 01:24 PM
where they are grounded, is it painted?
make sure the bolts are touching metal
Old Sep 29, 2009 | 01:57 PM
Polaradude's Avatar
What ignition is on the car ? Ballast resistor etc etc ? Ignition module ?
Just thinking out loud.
Old Sep 29, 2009 | 06:55 PM
BuckNeccid's Avatar
Polardude is on the right track, if it's not a point distributor, you'll have to have some sort of ignition box to get it running. If it's a point type, check your gap and make sure they aren't burned. Pre set your timing by lining up your marks, powering the distributor, and then turn it till the points fire while you are turning it. You should be within a couple degrees of TDC there.
Old Sep 30, 2009 | 06:00 AM
Bossta's Avatar
Junior Member
Yes, points were gapped to 0.060" instead of 0.017"
Also, found a bad spark plug wire
We have spark!
Thanks!
Old Sep 30, 2009 | 11:07 AM
Polaradude's Avatar
Right on, glad we could help.
Old Oct 1, 2009 | 04:53 PM
does it run now?
will d
Jun 21, 2010 07:16 AM
MReeves
Super Gas
Mar 19, 2010 02:54 PM
73SatWag
Dec 14, 2009 01:55 PM
joe440
Jun 30, 2009 08:34 AM
Chris in Idaho
Dec 24, 2008 10:02 PM
