1968 coronet 440..rear main seal leak?
Old Jun 20, 2016 | 09:35 AM
68coronet's Avatar
Question 1968 coronet 440..rear main seal leak?
I just bought this car over the weekend and I notice theres an oil leak from in between the transmission and engine, so Im guessing rear main seal.
I was told by the prev owner that it was changed when he had the motor built.
when the motor is at operating temperature it leaks/drips around 1 drop per second.
Is it a straight forward job to replace this? pull tranny off and thats it? any heads up, suggestions would be highly appreciated.
thank you in advance.
Old Jun 20, 2016 | 10:16 AM
Are you sure that its not the oil sender that's leaking. It's behind the intake manifold to the left.
Old Jun 20, 2016 | 10:20 AM
As far as the rear main, you pull the pan for replacement.
It can be a pain in the ###!
Old Jun 20, 2016 | 01:25 PM
Yep... Pan comes off... Only way to get to the seal.. All depending on how your set up.. But some times pulling the Motor can be best...
Old Jun 20, 2016 | 02:01 PM
68coronet's Avatar
I'll get under it hopefully tomorrow and take a good look. I have done seal jobs on other motors (ls2, 2jz etc) but this time very busy with work so ill see if a shop is able to do it!
another question i have is, my oil pan sits pretty low..its a moroso and hangs 4 or 5" than the cross member. Is there one in the market thats good/short? Ill be lowering the car in the near future.
Thanks
Old Jun 20, 2016 | 07:45 PM
Check into putting the stock sump pan and pick up back on...... Unless there is a reason that it would not work?
Old Jun 21, 2016 | 06:02 AM
You can adjust the pan depth by breaking a ring and pinion with the front wheels about two feat in the air, it has worked for me.
Old Jun 21, 2016 | 09:18 AM
Sounds like "Clearancing" too me....
Old Jun 21, 2016 | 09:29 AM
That's with 2" spacers on the bump stops.
usedknobby
May 19, 2015 09:12 PM
usedknobby
Jun 2, 2014 01:38 PM
fastdakota84
Jul 26, 2010 02:46 PM
DandyD
Apr 19, 2010 02:48 PM
SPICOLIE203
Aug 28, 2009 07:23 AM
