1987 318 with electronic spark control
Old 12-17-2014 | 08:51 AM
moerules's Avatar
I am in need of some help please. I have a mint 87 5th ave. for my daughter who starts driving in in two days. It has been sitting for a couple months waiting for her well i took it to fill it up and it started running terrible. it seems when engine is cold it runs great but after about ten minutes i can not give it anything more than 1/4 throttle. when i do it bogs out and backfires out the exhaust
until i let off gas. sitting still i can get the engine to rev if i apply gas slowly, but if given more than the 1/4 throttle bogs and backfires. i would like to repair it if possible if i knew what to look for!! I did a dist. swap on my old 79 magnum 25 years ago but really don't remember all involved with this.
If i cant get it running properly in its current configuration what are my other options?? switching out to ingnition box and older dist.?? How about one of the dui models with one wire hook up to eliminate ballist resistor?? will i have to swapp the carb out also?? and if so what would be best to use?? thanks for taking your time to read my book!!!!!
Old 12-17-2014 | 01:54 PM
Throttle Body Injection with box on the air cleaner can be troublesome.
http://www.allpar.com/fix/80s-codes.html
Old 12-18-2014 | 03:26 AM
moerules's Avatar
Pretty sure it not TBI just plain old carborator on a v8 from what I am getting the box on the aircleaner controls the spark but I will see if it throws any codes
Old 12-18-2014 | 08:42 AM
moe7404's Avatar
scrap that system. get the good old chrysler ignition system. easy to put on. very stable. easy to trouble shoot. here is are things to think about. Mopar dist cap wiring... vent
My dad made this saying about chrysler V8 small and big block dist cap wireing. To reduce wiring confuseion. “the small block has the dist in the wrong place, in the back of the engine. BUT the shaft rotates the right way clockwise. The big block has the dist in the right place, in the front of the engine BUT the shaft rotates the wrong direction counterclockwise. Both wire #5 and #7 on both ALL ways have #5 before #7 on the cap AND block. And most / some stock V8s have the fireing order cast in to the intake manifold. AND: DO plug the vent with JB-weld. Keeps the moursture out.
Old 01-01-2015 | 11:27 AM
moerules's Avatar
If i scrap the computer will it effect the trans ?? Was told it has something to do with he convertor locking up?? Not sure though
Old 01-01-2015 | 12:39 PM
By this it shows not, I believe they were centrifugal lock-up, but easily searched.
Click underlined blue lines for explanation of function.
http://minimopar.net/ecu/lm-1987-tbi.html
Old 01-03-2015 | 05:43 AM
moerules's Avatar
I have a manual for the 5th ave, diplomat and other rear drive vehicles from 1987 and it says it is controlled by the lean burn system computer or electronic spark control as its called in the later year. Coronet500 I believe you are giving info for the front drive cars as there was never a 2.2 in a rear drive car turbo or not. This is a caburated car that the spark and from what I am getting the trans lock up is controlled by the air cleaner computer. The earlier model torque converters where not electric lock up but seems to have changed in the middle eighties. Thanks.
Old 01-03-2015 | 07:14 AM
pro-tech's Avatar
Well my crystal ball is telling me that it is not a computer or ignition problem but it is a fuel problem. The fuel filter is plugged, Change the filter and see if it helps the problem.. A backfire is usually caused by a lean fuel condition...Bill
Old 01-03-2015 | 10:26 AM
Check the fuel pressure...
Old 01-05-2015 | 05:07 AM
moerules's Avatar
New filter and pump. Like I said runs perfect til it warms up say 10 minutes then just sounds like getting flooded out starts backfiring through exhaust til let off gas. I appreciate the help but believe its the spark control or a sensor not telling it to advance spark . possibly accelerater pump or carb
Old 01-05-2015 | 09:03 AM
Check the Coolant Sensor for the ECU?
Old 01-05-2015 | 10:35 AM
DDodger's Avatar
if this my car, convert and get away from lean burn
Old 01-08-2015 | 07:31 AM
moerules's Avatar
i would be happy to remove the lean burn set up if someone can confirm it will not effect my torque convertor locking up. i did so on myold 79 magnum 20 years ago was simple but then again it did not have a elctronic lock up. i will see about checking the sensor when it warms up a bit here -20 with wind chill today thanks for all the responces
buttton
04-01-2013 10:00 AM
austin
09-18-2012 12:37 PM
Arich
05-25-2012 12:28 PM
jeff1010
08-06-2011 01:33 PM
hellzombiex
03-13-2009 02:45 PM
Quick Reply: 1987 318 with electronic spark control
