2002 4.7L Pre-oiling rebuilt
Old 02-24-2012 | 08:02 AM
02QuadCab1500's Avatar
Purchased a Gearhead rebuild, need to Pre-oil via pressurized oil through oil sender hole... Small threads, need to know if anyone know if it is 1/8" pipe... Straight metric, SAE...
the process requires using/making a pressurized oil vessel to feed the oil channels just prior to start-up... minimizing/eliminating the dry run time.
Old 02-27-2012 | 05:06 PM
Craig Kozak's Avatar
If you use, assembly lube on the crank bearings, rod bearings, lifters/etc and coated the cylinder walls in oil you won't have a issue with damage.
Old 02-28-2012 | 07:24 PM
scotts74birds's Avatar
I just dont think that pre-oiling on these is an issue. 4.7's have alot of issues. I dont think pre-oiling will fix them. Why do you think you need this?
dpmalibu
06-20-2013 08:51 PM
Jaykeane
06-01-2011 06:13 PM
bugy
02-01-2011 08:51 AM
1966DartConvertible
11-25-2010 09:57 PM
HemiSilva
07-08-2009 04:03 PM
Quick Reply: 2002 4.7L Pre-oiling rebuilt
