318-360 torque converter
Old Mar 19, 2012 | 07:32 PM
mebebob's Avatar
if you had a new 318 converted and you needed it for a 360 what do you thing about grinding the weight off the 360 one and welding it on the 318 converter.??
Old Mar 19, 2012 | 08:46 PM
I am not sure but I don't think it is as easy as that said.
Old Mar 20, 2012 | 02:15 PM
mebebob's Avatar
the converter only bolts on one way. so i was thinking the weight is for the motor anyways not the trans. so welding it on is pretty hard to screw up ...
looking for more imput
Old Mar 20, 2012 | 02:27 PM
I've never felt that welding weights on is a good idea. GRAMS as in fractions of grams, make a difference in engine balance.
I'd say buy a B&M or similar aftermarket flexplate which has the necessary balance built in. That way, you can use a "neutral balance" converter, which makes your selection broader, as well as being able to use that converter if you ever change to a different engine balance situation.
I have a factory 360/ 727 in mine, but when I get a stall converter, I've already got a BM flex to go in there.
Old Mar 20, 2012 | 02:53 PM
The make a kit for the 360 converter Comes with the weight and a templet for position / welding
I used the B&M flex plate with my 360 motor
Old Mar 20, 2012 | 03:57 PM
One of my Favorite sayings is "Going a tad bit cheaper is not always better" that being said make sure you have a good nuetral balance convertor and that B&M 360 flex plate.
74cuda
Cuda Specific Discussion
Sep 8, 2017 04:08 PM
67Polara
Jul 28, 2012 01:49 PM
Nomadci
Aug 23, 2010 02:50 AM
smackhonda
May 26, 2010 07:17 PM
68 gtx
Oct 16, 2009 03:43 PM
