318 help
Old Feb 5, 2012 | 10:09 AM
Tnmopar's Avatar
318 help
318 n 72 plymouth sattilite - ran fine are
At idle but would stall out when given gas, now will not run. Replaced all spark parts
Any help would be great.
Old Feb 5, 2012 | 07:12 PM
Carb/ fuel problem.. Have you checked to see if the accelerator pump is working Have you checked the fuel pressure ???
Checked for spark ??
Old Feb 5, 2012 | 08:15 PM
moparted's Avatar
timing chain?
Old Feb 5, 2012 | 08:26 PM
blue 68 gts's Avatar
If it was a timing chain issue it would most likely run like garbage at idle, under accel, decel, ect.
I'd say Carb or Fuel issue as well. Try going through the carb, make sure it's not gunked up. Check for fuel pressure like TV lynn suggested.
EDIT: Any mods done to this 318?
Old Feb 6, 2012 | 05:35 AM
Archer's Avatar
Tn -
Kinda hard to tell form your description (meaning could be anything). Check the easiest things first - look for vacuum leaks and timing changes.
Old Feb 6, 2012 | 11:10 AM
Ballist Resistor?
Old Feb 6, 2012 | 11:00 PM
Ballist Resistor?
Ballast resistor will not cause this issue.
Old Feb 6, 2012 | 11:55 PM
"now will not run".
Sure it will Nick. His last quote was saying it will not run. Let off the key and the car dies.
waham87
Feb 22, 2013 06:46 PM
hcharles
Feb 5, 2011 03:52 PM
TallChris
Dec 1, 2010 03:29 PM
LittleSpark
Jan 15, 2009 09:06 PM
ProEmaster
Jun 6, 2007 11:31 AM
