318 LA rocker shaft removal
Old Jun 19, 2017 | 05:20 AM
Gibby's Avatar
Currently working on removing my rocker shaft off a 66 318 LA engine. I know in order to remove it the rocker shaft lock plug must be released. Does anyone here know how to pull this plug and then slide the shaft out? what tools did you use and what process did you use to remove it?
Old Jun 19, 2017 | 10:16 AM
I must be missing something here.... A Photo Might help....
But as far as removing the O.E.M. Rocker Shafts on an L.A. motor... Just unbolt the shafts and remove the assembly.
Old Jun 19, 2017 | 11:59 AM
Gibby's Avatar
Already figured it out there was a small plug that had to be pulled to release it
Old Jun 19, 2017 | 04:03 PM
? The plug on the end maybe 3/4" does not normally get removed except for cleaning.As you have found out the rocker shafts un bolt
mwerner
Aug 29, 2016 10:19 AM
Robert Weaver
Sep 29, 2014 07:31 PM
69POLARA383
Jul 16, 2012 10:39 AM
DartSwinger
Aug 3, 2010 11:18 AM
scotts74birds
May 13, 2009 04:22 PM
