318 running problem
Old Oct 10, 2022 | 11:11 AM
Edgar greenwood's Avatar
318 running problem
My friend has a1990 model 318 that just goes dead while driving you can set there for the count of 25 and then crank it up. He has changed water pump timing chain filter, retimed it new coil new fuel pump we don't know what to do next
Old Oct 10, 2022 | 04:41 PM
Kuvasz101's Avatar
You need compression. ignition and fuel to run. I say you could eliminate compression. As far as when it dies take a look down the carb and see if it's getting fuel from the accelerator pump while opening and closing the throttle. If that is good, it's ignition. Pull the coil and see and listen for a spark as you arc it across metal while cranking.
Old Oct 12, 2022 | 10:31 AM
check the grounds to the VR, as well. that goes, the car shuts down.
dtperrell
Oct 11, 2013 10:43 AM
dyera1
Apr 7, 2013 03:02 PM
Tnmopar
Feb 6, 2012 11:55 PM
68Polara500
Jul 28, 2011 10:51 PM
Aspen
Sep 1, 2009 08:10 PM
