34 Dodge - Maiden Voyage - Better Exhaust Needed
Old 05-29-2014 | 08:00 AM
hckrphil's Avatar
So last night I took my '34 Dodge around the block for its maiden voyage.... see here:
Right now, both sides dump down into 3", into an H pipe, and then both sides go thru Hedman 3" glasspacks and right out in front of the rear wheels.....
This setup is LOUD..... Ideally, I'd like to cut the glasspacks out and swap in some nicer mufflers that will help tone it down a bit.
1- Is it possible to tame my nearly 500HP Mopar 440 big block?
2- Dimensions I need to stick within: 24" long, 4" high
3- I'd need mufflers with an offset input and output, both on same side
I'm somewhat familiar with flowmasters, magnaflows, borla.... are there other brands out there that will produce just as nice of a sound for perhaps cheaper? Anything that could be picked up locally at a Pep Boys / Advanced / Autozone?
I'm open to suggestions / opinions...
When I built the car, I called several different torque converter places, and I gave them my engine specs..... they pretty much all suggested a 3000 stall converter. So that is what I put in.... HOWEVER, after driving the car, you have to really get those RPMs up to get it moving, which in turn makes it LOUDER.
Thanks everyone!!!
~Phil
Old 05-29-2014 | 08:55 AM
62Furious's Avatar
looks great don't know of any mufflers that enter and exit on the same side. best of luck on your hunt to quiet your ride down.
Old 05-29-2014 | 10:06 AM
Check With SpinTech....
http://www.spintechmufflers.com/
And Also
http://www.extrememufflers.com/
Both can tailer to your needs.....
Old 05-29-2014 | 02:35 PM
hckrphil's Avatar
Thanks everyone...... I'll let you know what I come up with as well as more car videos / updates
Old 05-29-2014 | 05:55 PM
moe7404's Avatar
try this. neck the last 2-3 inchs of the pipe down by 20-30 %.. i had a 300 J with a 500" max wedge with two glasspacks on each pipe. and it was loud. but the reduced size helped a lot with no loss in power.
Old 05-30-2014 | 05:53 AM
hckrphil's Avatar
Here you can see the exhaust dump....... it is already narrowed down by quite a bit....
I think what I'm going to try to do this weekend is cut out the existing glass packs, and weld in some Flowmaster 50 Series Delta Flow mufflers. We'll see what that sounds like Anything has to be better than what it is now I'd think?
~Phil
Old 06-01-2014 | 06:59 AM
hckrphil's Avatar
Exhaust system is all welded together... I just have to finish painting it with some high temp paint today and I'll be trying it out later....
Cut off the glasspacks and welded in some FlowMaster 50 Series Delta Flow mufflers. Should be a decent improvement... we'll see.
~Phil
Old 06-01-2014 | 07:46 AM
Hope you got a nice fit?
Old 06-01-2014 | 09:33 PM
hckrphil's Avatar
It's tight under the car..... but fits perfect. .... Fired it up for a little bit in the garage tonight..... less "tinny" and more bassy sounding now. It was late so I didn't wanna run it too long. Hoping to get it outside tomorrow after work...
Old 06-02-2014 | 10:11 AM
Sweet !!!!!!!!!!
old tired rebel
06-23-2010 09:13 AM
crwchf16
12-12-2009 06:44 PM
Valcam
06-05-2009 12:47 AM
Elmo
09-12-2008 06:46 PM
Yorkie Mama
04-07-2008 12:33 PM
