360 Gaskets
Old May 27, 2017 | 03:20 PM
gearheadmike's Avatar
360 Gaskets
I'm sure this is been brought up a lot but head gaskets. lol
I got a stock 360 edel intake headers that's it. I'm engine going together and idk if i should just get a felpro kit and run it or go with separate head gaskets?
Someone said any help in bumping up the compression in these small blocks help. My heads have been resurfaced but block hasn't been touched far as decked or anything.
Old May 27, 2017 | 05:58 PM
You can run either head gasket.... Steel Shim or Fel-Pro...
But to answer your question.... The steel shim with give it a slightly higher compression.
Old May 27, 2017 | 09:42 PM
I was thinking steel shim but will i run into any issues with intake manifold gaskets/bolt alignment? heads had .006 removed as one was slightly warped
Old May 27, 2017 | 10:25 PM
Shouldn't be a problem.........
Old May 28, 2017 | 05:56 AM
I'm With Iowan...
rickyr
Jun 26, 2011 05:39 AM
SteeleRubber
Jun 14, 2011 10:13 PM
SteeleRubber
May 27, 2011 07:11 AM
SteeleRubber
May 26, 2011 07:50 AM
Barfly
Apr 20, 2011 09:42 PM
