383 EXHAUST HEADER SURPRISE! WTH????
Old Apr 15, 2021 | 09:29 AM
67Barracuda's Avatar
Inspired by the 67 Barracuda that I bought new in 67, my '23 TBucket has a Mopar 383 engine. Today I decided to remove the exhaust header to do some work on it. It's held in place with 4 studs/nuts and 2 bolts at the #8 cylinder. To my surprise, when I removed the bolts water came out!! I haven't had any indication of water in the cylinders, or anywhere else that it shouldn't be. I'm not familiar with the internal passages in these heads. Should I be concerned???
Old Apr 15, 2021 | 10:41 AM
Archer's Avatar
67 -
Concerned - yes.
Where did it come from - not enough info.
How long has it been sitting, and where has it been sitting?
Do you have pure water in the radiator or part anti-freeze?
Old Apr 15, 2021 | 10:57 AM
The car is garaged in Arizona and is driven at least once a week, including yesterday. The coolant is a water - antifreeze mix, mostly for rust prevention. The motor has about 5K miles on it or so. I've been chasing a misfire issue for a while, tweaking timing and carb settings. As I said, there have been no signs of water in the exhaust or anywhere else.
PS - I just pulled one of the bolts from the other side and also got water, so I'm assuming that it's normal. But I'd still like affirmation from someone else. THANX!!!
Old Apr 15, 2021 | 12:23 PM
Archer's Avatar
67 -
If you have a water - anti-freeze mix, if it were coolant coming out of the headers, it should have the same tint.
It looked like clear water.
Also, (if I'm seeing the picture right), it seems like it's pouring out, too much for simple condensation.
If it's a few drops, it's condensation, normal, but still not great.
Old Apr 15, 2021 | 01:59 PM
fivepoint's Avatar
My 440 does that too. The manifold bolt holes go into the coolant passages. Its not a problem. Put thread sealant on the threads when you assemble it. If you can use studs on those holes, it would be better.
Old Apr 15, 2021 | 03:00 PM
Thanks!! I think I'll stick with the bolts, but I'll definitely use sealant on the threads.
Old Apr 15, 2021 | 05:37 PM
fivepoint's Avatar
Thumbs up
By the way, nice looking ride
Old Apr 15, 2021 | 08:14 PM
Thanx!! So's yours!
Just looked at your profile. USN myself. Reserves '63 - '69, FTM3, USS Springfield CLG7 COM 6thFLT '65-'67. Would have made it my career but I saw my oldest daughter for the first time when she was 8 days old and the next time I saw her she was 14 months. Turned down a commission for that reason. (I cried on my 39th birthday!! "I COULD HAVE RETIRED TODAY!!" :-) )
Old Apr 16, 2021 | 08:12 AM
Yep... Those holes are drilled all the way threw... Sealer will seal them when you put it back together...
Nice Ride.... Thank You for your service !!!
flboy0638
Aug 9, 2017 09:20 AM
Doba76
Mar 30, 2017 08:14 AM
66dartvert
Dec 4, 2016 02:21 PM
Roadrunner1
Dec 1, 2016 12:52 PM
69POLARA383
Jul 19, 2012 06:13 PM
