383 Timing, Fuel or both?
Old Apr 18, 2021 | 08:23 AM
67Barracuda's Avatar
The 383 engine in my TBucket had an issue that caused it to sputter and backfire whenever I punched it. I tweaked the timing and carb adjustments and had it running flawlessly. Now it's back and worse than ever. At idle it runs rough and only gets worse when I'm driving it. It acts as if the plug wires are cross-talking, or a cracked cap, bur neither of those are happening. One noteworthy (I think) symptom is that the left bank is running much richer than the right as you can see in the photo.
Any thoughts?
Oh, and before you ask - Holley 650 dbl pumper, choke disabled, Petronix billet distributor and Flamethrower coil, Vacuum advance disabled, centrifugal advance springs in place.
Old Apr 18, 2021 | 04:34 PM
Try a power valve
Old Apr 19, 2021 | 10:09 AM
Depending on how the old plugs came out..... I would say that looks more like condensation soot? Just a cold start build up of light unburned fuel...
Check vacuum leaks and also... As Iowan said, Power Valve could cause over enrichment.. Also Check the Float Adjustment...
Old Apr 20, 2021 | 08:44 AM
Problem solved!!!!
Thanks, everybody. I found my problem. I cleaned all 8 plugs, which were completely fouled and black, then I re-checked the idle adjustments and found that both of the driver's sides were opened about a half turn more than the passenger side. I set them all to 1 turn and it's running beautifully again.
I have a new question, but I'll start that as a new thread.
Thanks again!
John J.
Sjzdx
20
Jan 8, 2022 09:03 PM
70newport
Jul 15, 2015 02:33 PM
440Aspen
25
May 19, 2015 12:14 PM
traveeee
Sep 8, 2014 10:41 AM
frozen 1
Sep 29, 2012 01:09 PM
