383 top end kit 400 engine
Old May 17, 2023 | 05:46 PM
mhwardrobe's Avatar
Is a 383 top end kit compatible with a 400?
Old May 17, 2023 | 06:55 PM
Yes but you need to pay attention to compression ratio and cam duration. The 400 is a very low compression ratio engine (8.0) so head cc makes a difference. Cams with more duration will lower the dynamic compression ratio, so it might be a situation where are you mill brand new heads a few thousands.
Compression and timing is the key for getting the BBM to run, I run 9.5 with iron heads and premium unleaded aluminum heads can generally go a full point higher. It’s fairly easy to make 500hp with iron heads.
Old May 17, 2023 | 07:07 PM
mhwardrobe's Avatar
Thank you
1968newport
Jan 1, 2013 12:59 AM
dboykin
Oct 3, 2012 07:04 PM
stickshifted
Jan 16, 2012 09:37 AM
Polaradude
Jan 4, 2009 11:56 AM
CLJohnny
Dec 12, 2008 11:45 AM
