3RD gen HEMI decking/milling
Old Nov 2, 2019 | 01:46 PM
jeepers creepers's Avatar
Hi guys, i'm on the process of rebuilding a 2003 5.7 Hemi , i had the block decked and heads, both just barely touched because they were straight , did it to get a very good sealing surface, i told the machinist to take out the very minimum because i know pistons and valves clearance on these Hemi are very tight, that said , what's the maximum amount of milling considered safe to avoid piston touching valves and combustion chamber? Piston to head clearance is fairly easy to determine but piston to valves it's way more difficult and time consuming so i'd like to avoit it if possible.
Machinist told me that keeping the milling to very a minimum would be something like 0.0010 total , i mean block decking plus heads milling, i hope he did it this way.
I know Cometic makes thicker head gaskets but i already have a stock set to put on.
I found on some forum that someone took out something like 0.040 from the heads with no issue...What do ya think?
Any help would be greatly appreciated.
Old Nov 2, 2019 | 05:50 PM
.050 clearance is what the rule of thumb is. Just my 2 cents.. But we all love to push the envelope....
Old Nov 3, 2019 | 01:34 PM
Thank you
hemiaction
Sep 1, 2017 01:09 PM
GOSFAST
Dec 6, 2014 02:29 PM
rcknrolfender79
Oct 16, 2014 12:52 PM
TerryThib
Sep 4, 2009 09:06 AM
deadkelly
Jun 3, 2009 10:15 PM
