440
Old Mar 24, 2016 | 06:09 PM
demetri's Avatar
440
Anybody has experience with this distributor?
http://www.jegs.com/i/Speedmaster/74....1115/10002/-1
The main reason I am considering replacing my old distributor is so that I can easily change the mechanical advance curve. The second issue is that I cannot find a vacuum advance canister. All the other distributors out there are very expensive, this seems very affordable.
Also, if I do stick with my old distributor ... Where can I find stiffer springs? Second ... How do I take it apart? This last one may sound odd, but I have never disassembled a distributor before, and I do not recall the shop manual describing that. If I have replacement springs, then it would be worth looking into disassembling it.
Thanks
Old Mar 25, 2016 | 06:52 AM
DDodger's Avatar
"Stiffer" springs? Most of us want LESS spring. The shop manual most certainly details distributor service, it's in section 8
I don't know much about the chineseeoated import distributors. There are some sold by a guy "Skip White" that seem to have a fair reputation...at least with small blocks
Any OEM distributor made after about 71 will need recurved for performance, and especially with a bit of big cam. If you have a single point or breakerless (NOT a dual point) the outfit "FBO" sells a simple recurve "plate" (limiter plate) that some guys have used.
Old Mar 25, 2016 | 10:33 AM
demetri's Avatar
Well, yes, stiffer spring means less centrifugal advance, right? Yes, I need less total mechanical advance. I have a 68, my guess is that the distributor is pre 72 because they moved to electronic ignition in 72. I think I probably do need a re-curve, my idle is pretty bad. I will call FBO, thanks for your suggestion.
