440: Blowout @ EGR port?
I was demonstrating the new found responsiveness* of my Mk3 to friends by blipping the throttle from idle to full throttle and in doing so, I noticed "smoke" coming out from the opening between the intake manifold and the heads where there appears to be a pipe running from the intake manifold through the head to the exhaust side of the heads. I would appreciate comments and pictures if available of what could be happening here.
1st prize would be if I could completely block the the exhaust gas from coming back through the heads to even reach the intake manifold. Any suggestions?
*My 440 is now running with distributor-less ignition using two EDIS coil packs and Megasquirt-2 ECU.
Should I use an intake/head gasket that has the port blocked off?
I recon its both. This car was most certainly fitted with EGR stuff.
