440 coolant restrictors?
Old May 5, 2014 | 08:20 AM
demetri's Avatar
I am trying to build my own thermostat substitutes from fender washers. The ones I ordered have a thickness of 0.050-0.080. Does anybody have a block sitting there, so that they could remove the thermostat housing and measure the depth? I want to make sure that the washers are not too thick for the housing. The old thermostat I have has a flange of about 0.055 thick, so there must be at least that much room in there ...
Thanks
Old May 5, 2014 | 10:17 AM
These wont work?
http://www.jegs.com/i/Moroso/710/634...FYJqfgodrSgAjQ
Old May 5, 2014 | 01:40 PM
demetri's Avatar
These are not for Chrysler 440. But at any rate, I already have the washers, they are 0.057". Will that fit in the housing?
Thanks
Old May 5, 2014 | 07:56 PM
on sure....Measure the thickness of the old stat...
Old May 5, 2014 | 08:14 PM
demetri's Avatar
Did that. It is a little over 0.050". But I do not know if that is a tight fit, or there is some clearance in the T-stat flange ...
Hope the second.
Thanks
Old May 6, 2014 | 06:12 AM
Use play-dou.... Squish it.... Measure it.... add the gasket measurement and you'll have what you need for info >>>>
hckrphil
Jun 17, 2014 09:53 AM
mytracy
Dec 24, 2010 11:19 PM
pjjaramillo
Aug 30, 2010 11:22 AM
MarkyMark12345
Jan 31, 2010 09:30 AM
64fury
Sep 5, 2008 06:32 AM
