440 crank won't rotate with rod #4 installed
Old Jan 27, 2018 | 03:45 PM
Bullet18's Avatar
I'm currently rebuilding a 76 motorhome 440 to put in my 70 Challenger and am having a problem with rod #4. I have been torqueing all of the rods to spec back to front and turning the engine over in-between to make sure nothing had seized. As soon as I torque rod #4 to spec the engine will no longer turn over. If I torque rod #3 to spec without #4 it turns over fine and if I don't torque the bolts all the way to spec it turns over fine. I checked the bearings and everything seems fine. Does anyone have any ideas about what is causing this and how to fix it?
Old Jan 27, 2018 | 05:39 PM
Archer's Avatar
Bullet -
Remove the #4 rod and piston.
Torque the bolts (out of the block) and see if there's free movement on both ends.
Also look for score marks on the cylinder.
Old Jan 27, 2018 | 05:43 PM
If you have no equipment use a piece of plastic gauge and check the bearing clearance
Old Jan 27, 2018 | 08:11 PM
Sounds like the rod is out of round... Or the crank might be twisted in that rod journal ?
Old Jan 28, 2018 | 12:39 PM
Notch forward? Piston in backward having bearing pinch in the journal radius.
Old Jan 28, 2018 | 08:27 PM
Rod cap on backwards?
shifter
Mar 31, 2017 07:49 PM
69POLARA383
Jul 10, 2011 10:04 PM
atowncris
Nov 19, 2009 12:48 PM
1973charger
Jun 4, 2009 11:40 AM
azzkikr
Mar 3, 2008 08:45 PM
