440 differences?
Old Sep 12, 2012 | 03:27 PM
440beep's Avatar
440 differences?
I've looked and looked and can't really find anything that identifies the differences, if any, between 440 blocks. Wasn't there just a plain 440 block and also a 440 high performance block? If so, how are the differences identified? And are the differences significant if I'm only after the block and heads?
I'm looking for another 440 block to build up, and just curious if it matters what year or designation the block is. I saw that some of the 70 blocks had lower compression.
TIA
Old Sep 12, 2012 | 05:28 PM
It doesn't matter what year for all intent purposes they are all the same./ Except for later 70's had a cast crank, and the 6 pack had different balancing factors. Early 440's had a steel crank That is what I would look for
Old Sep 12, 2012 | 06:23 PM
440beep's Avatar
Ok, thank you. Going to stroke the motor anyways, so don't really care about the rotating assembly.
Old Sep 12, 2012 | 07:31 PM
Try this: http://www.440source.com/blockinfo.htm
Old Sep 12, 2012 | 09:01 PM
Coronet 500 said what I was going to say.
Old Sep 13, 2012 | 06:09 AM
440beep's Avatar
Thanks Coronet!! Found that 440 article last night also.
BigVasey
Feb 26, 2015 01:55 AM
Duster360
Feb 29, 2012 05:07 PM
Kotobuki
May 17, 2011 09:40 AM
atowncris
Nov 19, 2009 12:48 PM
