440 rear main seal
Old Jun 1, 2014 | 05:07 PM
usedknobby's Avatar
440 rear main seal
Dang neoprene rear seals, third try at putting one in seems each time the leak is worse. Going to give up and go to the rope seal. Can it be done with motor in the car? Can you loosen the main bearing caps enough to get it in? Only way I've ever installed rope seals was during crankshaft installation on engine stand from my memory you stuff it in the housing so having a hard time believing you can roll one in. Any experience in putting one in with motor in car would be much appreciated. Thanks
Old Jun 1, 2014 | 06:01 PM
IF you have had that much bad luck trying to get it to stop sealing. I would just pull the motor and do it...
Old Jun 1, 2014 | 08:56 PM
Is it the seal or the side seals ?????
Old Jun 2, 2014 | 01:38 PM
usedknobby's Avatar
We used black rtv on the side seals instead of the orange strips, filled the groove before sliding in the seal housing, couldn't coat the backside because the transmission is hooked up but could see rtv oozing out the length of the housing also cleaned all the surfaces with carb cleaner so rtv could adhere, so in answer to your question how can I determine whether it's the side seal or main seal?
usedknobby
May 19, 2015 09:12 PM
raycan2
Aug 5, 2013 05:22 PM
fastdakota84
Jul 26, 2010 02:46 PM
DandyD
Apr 19, 2010 02:48 PM
SPICOLIE203
Aug 28, 2009 07:23 AM
