440 timing
Old Apr 29, 2015 | 11:08 AM
440Aspen's Avatar
440 timing
new to the site !!
i have a 440 in my car. its got me kinda a little puzzeled..
when i pulled it out this spring the car does not want to idle.
driving down the road i can also feel the car surge...
carb is ok after double checking ( eddie carb)
when setting the timing it seems like the vac. adv. isnt coming in. the mark on the balencer doesnt untill about 1500 rpm then dives off.... when leaving a red light it chuggs and sputter and need to be 2 footed till it reachess 1500 rpm then takes off..
Ive checked :
plugs
wires
cap
rotor
carb 2,3,4 times.
vac leaks 2,3,4 times.
msd
etc!!!!
Car has:
stock mostly 440
eddie intake and carb
mild cam
2500 stall
headers .
msd box and coil
Any ideas
Old Apr 29, 2015 | 12:25 PM
Drag Pak's Avatar
You could check for clogged idle air bleeds .
Old Apr 29, 2015 | 02:50 PM
440Aspen's Avatar
also when timing is set (pretty much doesnt matter where) somtimes i can get it to idle but ALWAYS pings after 3000 rpm ...ive had anywhere from 32 to 42 total ... really getting frustrated!!
also fo what its worth ... while its runnings if u detach the vac hose and suck it takes alot to make it move ...
really makes it hard to love mother mopar sometimes!!
Old Apr 29, 2015 | 03:03 PM
Sounds like the carb is gummed up.. What is the compression of the motor ??? As to the timing I would get a timing tape and install.. With the vacuum advance disconnected run the motor a 3K and a just for a max of 36 deg. Then check it at Idle IF it is not at least 10-12 deg you need to modify the advance curve in the dist....
Another remote possibility ? If you have an adapter to a spread bore manifold it may leak ???
Old Apr 29, 2015 | 04:47 PM
440Aspen's Avatar
there isnt an adapter...and ive had the carb off and cleaned it ..it almost seems like at low rpms there is a miss. but comes to life after 1500 rpm only break up at 3000+ ...
also theres no vac leaks ..ive doubled and triple checked..
Old Apr 29, 2015 | 04:56 PM
Verify accelerator pump, fuel pump, fuel filter and TDC on balancer if stocker.
Your setting the timing with vac. advance disconnected and hose plugged, correct?
Old Apr 30, 2015 | 12:50 PM
Drag Pak's Avatar
Check the metering rod pistons have not dried up and are sticking. A drop of oil here works wonders.
Old Apr 30, 2015 | 01:23 PM
440Aspen's Avatar
Went over the carb again.. Complete tear down and clean and reassembled.. Still no change WTF!!!!
Old Apr 30, 2015 | 04:41 PM
We can go back & forth WHAT IS THE TIMING SET TO !!!!!!!
Old Apr 30, 2015 | 05:15 PM
440Aspen's Avatar
Right now as its sits in the garage is 12 adv 32 all in
but also ive had it from 8-15 adv and up as high as 42.. and always starts to ping after 3000 and is a C*&T from a dead stop till it hits 1500 rpm ... ive just order a new set of plugs and wires even though these ones now arent that old and and i had the plugs out last night and cleaned and re-gapped them...there a champion plug with taylor wires. but im gonna try ngk plugs and msd wires..(had good luck with them before) ...
Old Apr 30, 2015 | 07:00 PM
You're not answering all the questions your given so it hard to help you. If this is a problem that started after you got your car out this spring, it is probably fuel related. The alcohol in fuel is hard on rubber parts as in accelerator pump diaphragms that dry out and crack over the winter. You don't say how big the cam is but every 440 I've ever had has liked 35 to 39 total with a very short curve. If you are trying to time your motor with a damper with the outer ring spun, and I've had it happen on a 10 year old stocker, your not even close. The stumble to 1500 and the pinging could be a fuel or fuel/timing or timing issue.
Old Apr 30, 2015 | 08:53 PM
Fuel pressure ok????
Old May 1, 2015 | 07:36 PM
Drag Pak's Avatar
How old is the battery? Test the battery!
Old May 1, 2015 | 07:42 PM
Might still have some bad fuel in the tank???
Old May 1, 2015 | 07:44 PM
Swap the carb out and see if the problem goes away ???
Old May 6, 2015 | 07:07 PM
440Aspen's Avatar
replaced the battery cause it was weak .. but ive honestly havent even gone in the garage to look at it. but this weekend im gonna do a few things.. spark plugs and wire's gonna swap the carbs with a known good one. and im also changing the rear gears out.. so i will update after .. thanks for the help guys
Old May 12, 2015 | 10:10 AM
440Aspen's Avatar
all said and done.
found the vac. adv. was done. replace the canister and thru new plugs and wires on and running like top.
dialed the timing in and now its all well and good.
gonna run it on friday night and see what kind of # shell put up .
hoping to see 12's
Old May 12, 2015 | 01:12 PM
Keep us posted...
Old May 12, 2015 | 05:41 PM
How about some pictures and info on your Aspen, motor, trans and rear end etc.. I've got a 76 440 powered Volare with a B body 8 3/4 I first put together in the 80s.
Old May 13, 2015 | 10:30 AM
440Aspen's Avatar
440 bb ..
Mild cam not 100% which cam came in the car
Eddies carb and intake
Headers
2800 stall
456 gears
727 tranny with semi manual shift kit
Old May 13, 2015 | 07:48 PM
I like the color, is that an 80?
Old May 14, 2015 | 04:43 AM
440Aspen's Avatar
yes it is.. wrong grill tho.. im looking for a chrome aspen grill and chrome bumper
Old May 15, 2015 | 06:56 PM
I've had my Volare so long that I bought new quarters and a grill from Chrysler when I first put it together, had the rear bumper rechromed and I cast a fiberglass front.
Yours being a 80 and a one year only it might be easier to send it to a rechromer, and at one time you could get the grill after market.
Old May 16, 2015 | 07:45 AM
  #24
440Aspen's Avatar
yea ive been looking
Old May 17, 2015 | 07:19 PM
  #25
hoping to see 12's
So what did it run?
Old May 19, 2015 | 12:14 PM
  #26
440Aspen's Avatar
[QUOTE=Iowan;128674]So what did it run?[/QUOTE
didnt make it down there this past weekend... long weekend festivities caught up with me .. lol .. but ill going for sure this weekend .. im in the points series and its our first race..
19newport72
Mar 27, 2024 06:44 PM
Commando
Nov 19, 2013 06:45 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
67 GTX
May 4, 2011 12:46 AM
