440 water pump lower profile
Old Aug 17, 2014 | 02:14 PM
motasupra's Avatar
I wanted to know if there is a lower profile water pump for a 440? I’m having trouble fitting an electric puller fan on my new aluminum radiator because it is hitting the water pump pulley. I’m wondering if anyone knows how much less an electric pump would stick off of the engine. It needs to lose about 1” to fit. I can go with a lower profile fan but I want to replace the pump.
Old Aug 17, 2014 | 10:13 PM
Mount the rad on the front side of the rad support
Old Aug 18, 2014 | 05:40 PM
moe7404's Avatar
electric water pumps? one for each side. lets see tap the front of the heads?
Old Aug 18, 2014 | 06:10 PM
What !!!!
Old Sep 28, 2014 | 03:22 PM
motasupra's Avatar
Got it. spal medium profile fan and moroso pump just enough room
Attached Thumbnails 440 water pump lower profile-20140418_210756.jpg   440 water pump lower profile-20140821_193137.jpg   440 water pump lower profile-20140821_195105.jpg
Old Sep 28, 2014 | 06:43 PM
Fantastic, thanks for the update.
Old Sep 29, 2014 | 11:59 AM
motasupra's Avatar
With this setup we went to a local car show and got to take the car around town on full drag slicks. ha ha. with the timing 32 advanced 499ci with 10.3:1 on 110vp fuel the car took a long time to get up to 175 and kind of stayed there. it was 75f out side and we are not running a thermostat just yet.
The specs that they give you on jegs from mounting surface to end of pump are spot on.
So in the end its so far so good now we just need to make a few passes with this set up to see if it all holds up to tires coming off the ground.
SPAMBURGER
May 4, 2015 07:06 PM
rexus31
Feb 5, 2014 12:46 AM
fury_19
May 1, 2013 02:28 AM
power wagon
Jan 8, 2013 11:33 PM
bzau
Jun 18, 2011 05:07 AM
