440 won't start until it cools down about 30min?
Old Jul 31, 2011 | 11:12 AM
Marc Greenleaf Jr's Avatar
Timing set to 10* BTDC Runs Great until I shut it down and let it sit about 5-10 minutes then it won't fire until is sit another 30mins.
What do you thik might cause this?
Old Jul 31, 2011 | 01:13 PM
mr340's Avatar
Vapor lock, are the fuel lines routed anywhere near a heat source?
Old Jul 31, 2011 | 03:12 PM
Vapor Lock
Funny you should say that. I've noticed that the upper will have a pocket of air in it occassionally.
The main line from the pump to the carb is very close to the block and exhaust manafold.
How far awy does it need to be?
Old Jul 31, 2011 | 05:47 PM
Thanks!
Moved the fuel line off the engine block 2" and pow starts!
THANKS Mr 340!
Something so simple, it's stupid
Old Aug 1, 2011 | 09:45 PM
jasonduke31's Avatar
my 360 does the same thing does great when motor is cold after it warms up w in 5mins of shuttin it off it ll start w just a bump but after that it takes a min to crank my fuel lines are away from heat as much as possible
Old Aug 2, 2011 | 03:11 PM
Not an expert by far, but
From reading through other forums. I found some comments on timing and if it was not right your ignition spark could be affected after the engine gets hot. You might try there. I would think you would want to advance the timing closer to TDC, but I'm not sure. Maybe someone else has some better advice.
Old Aug 2, 2011 | 08:17 PM
what fuel pump do you have on the 440?
Old Aug 3, 2011 | 11:29 AM
bboogieart's Avatar
Befor Top Dead Center, BTDC is advanced.
Retard would make it closer to TDC.
Retard more and you get After top dead center. ATDC
Timing can indeed cause this if it is advanced too far it will try to start but kick back from flame front hitting the piston as it tries to come up against it.
10* btdc is about right.
By the way he fixed it read up a few posts. It was the fuel line getting hot.
Old Aug 4, 2011 | 10:08 PM
Just a generic 5.6 PSI Mr. Gasket. Can't spen alot of money just yet. The wifes not to happy about the car purchase. Need to let her get past it a bit.
zachb
Jul 19, 2014 12:15 PM
jbda
Apr 1, 2013 10:22 AM
76NY440_nTX
Aug 3, 2011 11:21 AM
fastdakota84
Jun 25, 2010 01:06 PM
MReeves
Jun 14, 2010 04:42 AM
