5.9l 360 magnum heads
Old Mar 19, 2015 | 05:34 PM
bully62's Avatar
I have a mopar 360 magnum 5.9l 405hp crate engine and am wondering what aluminum heads they have?
Old Mar 20, 2015 | 04:10 PM
xaza's Avatar
I think the Edelbrock Performer heads are the commonly used aluminum heads. I have the Mopar R/T heads on mine. You should be able to find a part number, on mine it is under the exhaust and pretty much impossible to see without taking stuff apart and out, though you might have more room under your hood.
Old Mar 20, 2015 | 05:12 PM
bully62's Avatar
Thanks
Old Apr 9, 2015 | 08:30 AM
bully62's Avatar
Found out I have 93-2000 360 magnum cast iron heads
Old Apr 9, 2015 | 10:52 AM
inri's Avatar
Bully,
The great news is that if you wanted to swap to Aluminum heads you could pick up at least 50hp/50tq with a mild port job, probably loose 40lbs on the top of the engine due to the cast iron vs. alum weight difference.
Win/Win for the future?!
Laura Cullen Reynolds
Apr 22, 2024 03:24 AM
maca
Feb 2, 2015 04:49 PM
johnboy
Feb 1, 2012 11:20 AM
cudaracer
Sep 26, 2011 02:43 AM
slim689
Apr 22, 2011 05:53 AM
