5.9l 360 magnum heads
I think the Edelbrock Performer heads are the commonly used aluminum heads. I have the Mopar R/T heads on mine. You should be able to find a part number, on mine it is under the exhaust and pretty much impossible to see without taking stuff apart and out, though you might have more room under your hood.
Bully,
The great news is that if you wanted to swap to Aluminum heads you could pick up at least 50hp/50tq with a mild port job, probably loose 40lbs on the top of the engine due to the cast iron vs. alum weight difference.
Win/Win for the future?!
Laura Cullen Reynolds
Apr 22, 2024 03:24 AM
cudaracer
Sep 26, 2011 02:43 AM
