68 Barracuda
Old Dec 14, 2012 | 06:44 AM
lloydpugh's Avatar
68 Barracuda
I'm fixing to build a 360 on hand to go with a 4 speed and a 271 possi rear in a 68 notchback Barracuda. Here's my early plan. Stock block checks out. Installing a SCAT crank, Eagle balanced rods, and Keith Black balanced pistons to gain roughly 10:1 copmpression. Plan to install Purple cam .429/.440, electronic ignition, air gap intake, 650 cfm, headers, reworked stock heads. I do not plan to race this. I'm a 57 year old kid fulfilling his dream. It will my street rod. Any sugestions or advice?
Old Dec 14, 2012 | 06:50 AM
Sounds good to me. May want to change that air gap to a RPM Performer instead. The air gap is for higher RPMs.
Old Dec 14, 2012 | 06:56 AM
Gorts 5th's Avatar
Smile
that will work
why the m-p purple cam? i'm assuming that's the duration/lift
you might want to check out other cam's there are some good threads in here to check out i'm learning allot, very good advice here!
Old Dec 14, 2012 | 10:43 AM
Chryco Psycho's Avatar
I would run the air gap especially if you have it , I assume you want to stroke this beast to 410 CI or so the 650 will be too small , I would use a minimum 750 cfm & I prefer the Proform carbs , they have incrediable tunability . I would rethink the cam take a look at the Lunati VooDoo line for the duration you can get a lot more lift .
Old Dec 14, 2012 | 06:36 PM
Mr.4spd's Avatar
Is the rotating assembly balanced or are the individual components balanced to themselves? It should be balanced as an assembly. Also, "posi" is a Chevy term. Mopar is Suregrip. Can't wait to hear of your progress. Photos?
Old Dec 14, 2012 | 10:17 PM
You would be much happier with at least a 3.23 rear gear
Old Dec 23, 2012 | 06:36 PM
PK1's Avatar
PK1
What heads are you using and how will you rework them?.
Your plan is rock solid. Good components and matched well.
I would pass on the purple cam as the technology has come a long way and there are some great new products available for the same price point. Its a good stick, don't get me wrong, and if you want it cause its mopar then run it.
But I would pick the cam last as you need to know what your heads are gonna do and how you are gonna run this.
Old Dec 24, 2012 | 09:20 AM
blue 68 gts's Avatar
A 650 cfm is NOT too small at all. I run a 650 HOLLEY on my 440 and made over 450 whp. Have run 11.40 - 11.60s with it ALL day long.
And i will agree on Lunati Voodoo cams. I run a voodoo cam in mine. Dont go with a purple shaft cam, theyre garbage now. They eat lobes.
Also.. if youre not planning on racing this, why are you uping the compression, putting in a built bottom end, head work, ect.... IF youre using it for car shows, just stick a stock 360 in with headers and drive it.
ProEmaster
Feb 11, 2008 11:23 AM
ruffinracin121
Nov 20, 2007 06:53 AM
ruffinracin121
Oct 29, 2007 08:32 PM
danuwells
Aug 30, 2007 11:45 AM
smitchell
Jun 11, 2007 11:40 AM
