'78 D100 refresh
Old Jun 28, 2015 | 07:03 AM
SPAMBURGER's Avatar
'78 D100 refresh
Well I finally got around to pulling the motor out of the old truck for some freshening up. It is a 440 with heads that have been worked over but I'm not sure what cam is in it now. I don't plan on doing a lot with it, just cleaning and a little dress up but was wondering if anyone has tried the whiplash cam from Hughes engines and if so how did you like it for a street/strip build? Also while I was pulling everything apart I noticed the exhaust ports have a ton of carbon build up and was wondering if this could cause a bog feeling just off idle.
Old Jun 28, 2015 | 07:08 AM
How much build up are we talking about?
Old Jun 28, 2015 | 07:30 AM
SPAMBURGER's Avatar
It's about a 3/8 -1/2" All the way around. The port is about half the size that it should be. I have been trying to tune out the bog feeling with the carb and timing but couldn't get it where it should be. If I hit it hard from idle it will sometimes die.
Old Jun 28, 2015 | 07:48 AM
Is this in all the ports?
Old Jun 28, 2015 | 08:50 AM
SPAMBURGER's Avatar
Most of the build up is I the crossover port on the intake side but there is a little in all exhaust ports. It has the crossover ports blocked off by the valley pan but there is a lot of crap in there. Is it worth it to pull the heads and clean out these ports or should I not worry about it since I'm not using them anyway?
Old Jun 28, 2015 | 10:38 AM
Does this 440 use oil at all, I've seen bad exhaust valve seals leave a build up in the ports, there's enough heat to burn off the oil but leave a hard crust in the ports.
Old Jun 28, 2015 | 10:50 AM
As I'm thinking about this, I don't think I've had one set of BB heads that didn't need guides worked, knurled, liners or bronze guides.
Old Jun 28, 2015 | 11:35 AM
SPAMBURGER's Avatar
It does use a little oil but I haven't really ran it enough to see how much. I have only owned it for about a year and have put less than 300 miles on it. I mostly tore into it because the engine bay was a mess and needed some clean up. It all started with a blown thermostat gasket and now I'm over $1500 into just dress up mostly. Funny how things snowball like that I guess.
Old Jun 28, 2015 | 12:01 PM
I think if I had the motor out, even without doing a compression test, I would pull the heads and have a valve job done.
Old Jun 28, 2015 | 01:06 PM
SPAMBURGER's Avatar
I think that is what I will end up doing. It will be a lot easier with everything out and accessible. Thanks.
Old Jun 30, 2015 | 06:19 AM
SPAMBURGER's Avatar
Does anyone have any experience with the whiplash cam from Hughes engines for a 440?
http://www.hughesengines.com/Index/products.php?browse=category&level0=RS0gQmlnIEJsb2 NrICAoUmFpc2VkIERlY2sp&level1=Q2Ftc2hhZnQ=&level2= V2hpcGxhc2ggTXVzY2xlIENhciBjYW1z&partid=30173
sgp7679
Feb 19, 2011 04:14 PM
chlngr1970
Sep 30, 2010 08:54 AM
33harner
Jun 28, 2009 10:56 PM
mopard100
Oct 6, 2008 02:38 PM
chlngr1970
Aug 1, 2008 09:26 PM
