automotive carburetor adjustable main jet, does it exist?
Old Sep 22, 2017 | 05:10 PM
dodgem880's Avatar
I was wondering.
On a carburetor, the idle circuit is variably adjustable by a needle screw, right? So, it's like a non-fixed jet? Why isn't that done with the main circuit?
That how it seems to work on older small engines, with the main adjustment on the bottom of the bowl.
I did a search and found this.
but, It looks like this for small engine/agriculture equipment. So... why not automotive engines? Why use a fixed jet that has to be changed for adjustment?
Or do I have this whole thing wrong and don't know how a carburetor works?
Old Oct 8, 2017 | 09:20 AM
dodgem880's Avatar
stupid question or too good of a question?
Old Oct 10, 2017 | 08:39 AM
ricks_RR's Avatar
what kind of a carb are you talking about what you showed was not on a car maybe on a model T or A
if you have more info that would help
Old Oct 10, 2017 | 03:33 PM
An automobiles carb will have multiple fuel circuits, each one dealing with a specific rpm or load to keep a consistent fuel mixture over a large rpm range. Small engine will have a much smaller rpm range and predictable single load making a simple carb with two fuel circuits enough to manage the demand.
When you look into auto carbs you'll find how complicated and precisely engineered they are.
dodgem880
Sep 22, 2017 04:01 PM
MorePar666
Apr 27, 2016 02:23 PM
Carsonartist
Jun 16, 2015 08:17 AM
Crazy4Carz.Com
Jan 9, 2012 06:52 PM
ucfierocharger
Oct 16, 2008 04:43 PM
