Big Block Drag Race Cams , what are you using
Old Jan 6, 2021 | 11:38 AM
Wes Breiten's Avatar
I have a 64 Dodge 330 drag car 3350 lbs with A 541 B1BS HEADS PORTED Iddy 449-2 int. single carb 4150. Per rules. T.F. 8 in 5600. 4.56. 10.5 29.5 w tires. The car doesn't run like I think it should. The cam is a roller ground for a 446. I had same combo its 273/278 .645/.630 on 107 ls. I think I need more lift 690-705 & more dur. 280-288 & 108-110 ls. What are ya'll running and results Thanks Wes
Old Jan 9, 2021 | 11:41 AM
Sounds like it dont have enough cam or compression... Looks like it hauling azz to me... Whats the problem?
Your not the "Wild Thang" Wes Breiten? from that group are you? out of Texas?
With that Beautiful Blue and White NSS ( Nostalgic Super Stock ) car?
Old Jan 9, 2021 | 02:48 PM
Yeah that be me. I have 13.4 compression in the mitor
Old Jan 10, 2021 | 04:16 PM
I'll just throw it out there for you.... I think the cam could / should be around .800 lift 280-290*@.050 with 7.1 Rocker ratio. with the heads flowing about 370 or better. should be a tad over 800HP with them heads...
I would look into the Indy R2 or CM2 camshafts with the 1,7 Ratio. (Also I dont think the Intake is big enough along with the carb 4150 and maybe a 900CFM with a spacer, If thats what you are running?) I would want to see flow a little more air with a 440-3 intake and a 4500 1200CFM-1250CFM and see if that picks it up...
I havent had a B1MC headed Motor in a long time, Things have come a long was scence I played with them....
However, Not sure what direction you are looking to go. But you may try speaking with the Nickens Brothers over in Conroe? That being if you get no help in your area...
https://www.facebook.com/Nickens-Bro...-257405521499/
Keep us posted.... Cheers
Old Jan 11, 2021 | 07:20 AM
I don't have that much motor. The heads are B1BS the sportsman heads. They flowed 335 @.600 before we opened them up to Max Wedge. I am limted to a 4150 casb. NSS rules. Going to buy one of the twin blade carbs a 1200. I have Comp cam. That's 287 .690 both intake & exhaust on a 108. Thats about all the lift I can get. Coil bind at .740. Right now you can't hardly get a cam. They are short on cores & 2 behind
gradedcatfood
Mar 2, 2016 07:02 AM
440Mag
Oct 1, 2015 10:07 AM
Charger'74_GER
Sep 4, 2015 07:33 PM
Gorts 5th
Oct 31, 2013 05:35 PM
woody02
Apr 25, 2012 07:15 PM
