Blown Intake ???
Old Mar 12, 2016 | 09:54 PM
Blown Intake ???
My 98 Dodge van 3.9 has been having ign problems. Driving at freeway speeds it shut off Then came back on with a loud backfire- like a gun shot and quit. Would still crank and try to start if I held the key on.. Would NOT hardly run sounded like 3 cyl guessing would not accept any RPM's Could I have blown the lower intake
Old Mar 13, 2016 | 08:00 AM
Could have... Or you might get lucky and it just blow off a hose you cant see?
On the before all that..... Did you feel it surge before banged?
I would think if it did, the van might have developed an ignition problem during the drive?
3.9 Full size Van? Rite?
So we are not sure if it was a lean bang or an ignition bang at this point? Hummmm
Time for a fuel pressure check also, is my thinking....
Old Mar 14, 2016 | 02:46 PM
I think It was an ign bang ? Was at a higher RPM when it happened I suspect the ign shut off and the injectors did not & it fired internally I don't know ? I guess i will have to remove the manifold
Old Mar 14, 2016 | 07:04 PM
Lynn,
You might want to "Smoke" that before removing it... That will tell you if it is really leaking..
OR
Plug off all the breather and any other ports.... Put a vacuum gauge in the Dip Stick hole... if the gauge goes negative.... It sucked the gasket....
Then again those are not too hard to do if I remember Rite....
Mango
Oct 27, 2010 06:32 PM
1966sportfury
Jul 11, 2010 10:25 PM
YellowDodge67
Jun 29, 2010 09:54 AM
sgp7679
Jun 20, 2010 10:15 PM
1972BBRR4
Jun 12, 2010 03:56 PM
