Cam question
Old Mar 18, 2012 | 05:24 AM
Bcrusep86's Avatar
Cam question
I just picked up a 318 yesterday with J heads, a edelbrock 318 intake and a edelbrock 600 carb ..What would be a good cam and lifter set i can get for it and where can i get it..im not looking for anything crazy just something that works well with what i got..Thank
Old Mar 18, 2012 | 06:19 AM
PK1's Avatar
PK1
Whats it going in? Tranny, gear, ac, power brakes, weight, tire size etc..?
Exhaust?
And most importantly, how will you use it the majority of the time?
Old Mar 18, 2012 | 06:31 AM
Bcrusep86's Avatar
It going in a 76 scamp with a 904 trans..no ac, stock rear, stock 4x5 wheels tires, 2 inch dual flowmaster 40 series and i plan on using it as a cruising car around town
Old Mar 18, 2012 | 07:00 AM
PK1's Avatar
PK1
Cool. Sounds like nice cruiser.
Here is my ten cents:
Making some assumptions;
stock stall, higher rear gears, 26-27 inch tire, exhaust manifold etc..
You have the 600 carb and the Eddie intake so you want your cam to work WITH what you have.
Comps 252H lists as a replacement cam but I actually like the way it works in stock apps.
Look at Comps XE250H if you are running exhaust manifolds. XE256H if you have a header on there. Both will have all their torque in by 3000-3300 rpm. Headers will stretch that peak up some.
Old Mar 18, 2012 | 08:02 AM
Good info from PK1, the 256 is the tipping point for this 318 combination where HP will increase but torque will drop dramatically as you go bigger.
XE 256 H = 301hp 365tq
XE 262 H = 305hp 362tq
At this point HP increases slightly, torque will drop like a stone.
Old Mar 18, 2012 | 11:07 AM
Bcrusep86's Avatar
Thanks for the information it has been a big help...so would this one be best for me to get? http://www.summitracing.com/parts/CCA-SK35-234-3/ Thanks again
Old Mar 18, 2012 | 12:58 PM
Get the proper flat or roller lifters for your engine.
I put this cam in my truck with their recommended springs, retainers and locks. Purrs like a kitten (kitty with a bit of an attitude) and loads of low end grunt.
Mopar_71
Nov 5, 2011 03:42 AM
Jay
Jun 3, 2010 10:24 PM
2002ram440
May 25, 2010 04:36 PM
silvermopar
Sep 20, 2009 07:26 PM
Mopar_71
Jul 17, 2009 06:05 PM
