Cam removal help
Old Mar 22, 2014 | 06:31 PM
mrzods13's Avatar
Cam removal help
I am trying to remove the cam in my 68 Newport. Took the fuel pump off and removed the distributor does the oil pump have to be taken off or do you pull thegear out because I know there is a bushing nust did want to pull it out and have anything drop into the motor.
Old Mar 22, 2014 | 06:42 PM
The gear has to come out
Old Mar 22, 2014 | 07:06 PM
mrzods13's Avatar
Does it just pull out or does the oil pump have to come out and what happens with the bushing.
Old Mar 22, 2014 | 07:37 PM
moe7404's Avatar
the fuel pump push rod may need to come out. a pipe thread plug under the fuel pump mount. take the plug out. the push rod should fall out. then check that the rod is not worn. if it is you need to a new one. on a room temp engine put grease on the rod, push it to contact the cam. use a small welding rod to hold the pump rod up, then tip the pump as you put it in. and bolt the pump on. then put the plug in. but i like electric fuel pumps. on carbed engine. i put a override switch to fill the carb before starting. saves on the starter, battery.
Old Mar 22, 2014 | 08:24 PM
mrzods13's Avatar
I took the pushrod out for the fuel pump, it is the oil pump gear that goes with the distributor, I took the distributor out I just want to know if the gear that goes into the oil pump the oil pump gear just pulls out with the bushing.
Old Mar 22, 2014 | 09:15 PM
moe7404's Avatar
you will need a new bushing. it should light press into the block. i all ways put extra groves in the face of the bushing to oil the shaft.
Old Mar 22, 2014 | 09:22 PM
mrzods13's Avatar
So no need to remove the oil pump so pull the shaft replace the bushing, but shaft back in after.
Old Mar 22, 2014 | 10:48 PM
Not necessarily.............!!!!!
Not clear to me DID the bushing come out with the gear?
IS the bushing worn?
If neither, might be no need to replace it.
Additionally, the bushing does not necessarily "light press in." ORIGINAL type bushings press in and become COMPRESSED. The installation tool BURNISHES the bushing as the tool is jacked back out of the bushing
There ARE aftermarket bushings which do not need to be burnished. Or so I've been told. DO NOT ream them!!!
REFER !!!! to your service manual!!! (which I know!! you !! have!!)
Service manuals............free........
http://www.forabodiesonly.com/mopar/...p?p=1970088617
Old Mar 22, 2014 | 11:21 PM
70redbee's Avatar
YES the gear needs to come out. Take a large screwdriver and put it in the slot where the dist. came out. Turn it counter clockwise and it will come right out.
Old Mar 23, 2014 | 05:28 AM
mrzods13's Avatar
Ok, I will work on getting it out, I thought I had to remove the oil pump that will save time now, still new at this so I am taking my time making sure I do it right.
Old Mar 23, 2014 | 07:18 AM
pro-tech's Avatar
Thats the smart way ask first...Most dont and wait until they are buried...Bill
Old Mar 23, 2014 | 08:30 AM
mrzods13's Avatar
It's hard to find pictures or any kind of references. Probably looking in the wrong places, so all I do is pull the oil pump gear out get the busing out after, then put new bushing in and put oil pump shaft back in.
Old Mar 23, 2014 | 10:42 AM
Originally Posted by mrzods13
It's hard to find pictures or any kind of references. .
It's all known as a "factory service manual and I already posted a link where you can download them..............free
To repeat. IF THE bushing is not worn DO NOT screw with it
Attached Thumbnails Cam removal help-bush1.jpg   Cam removal help-bush2.jpg   Cam removal help-bush3.jpg
Old Mar 23, 2014 | 05:14 PM
moe7404's Avatar
OK runner i totally forgot about the install of the bushing. sorry the bad thing is i have the 1967 manual right next to me. sometimes the old brain does not work very well. sorry.
Old Mar 23, 2014 | 06:14 PM
mrzods13's Avatar
thanks everyone
70plumchallenger
Mar 29, 2013 07:26 PM
T/A_NOW_ROADRUNNER
Feb 6, 2013 03:21 PM
Arbiter343GS
Apr 6, 2012 10:09 PM
TwistedWrenches
May 19, 2009 03:58 PM
Captainkirk2931
Jan 6, 2009 11:37 PM
