carb question
Old Jun 11, 2012 | 10:06 AM
plymouthrr1985's Avatar
carb question
Hey guys i have a street built 383 and have been looking for a good carb. The specs on the motor are 10.5 to 1 compression, lunati 60302 cam, ported edelbrock heads and intake and will be running tri 1 7/8 headers. Been lookin and a 770 street avenger or edelbrock thunder avs 800 or are these too big?
Old Jun 11, 2012 | 04:32 PM
Mr.4spd's Avatar
Transmission? Rear gear? If it's a stick car with 3.55:1 or steeper gears I'd drop a Holley 750 double pumper on it and never look back. Auto and/or highway gears, 750 Holley vac secondary.
Old Jun 12, 2012 | 09:53 AM
727, 3.23 gears for right now, planning on switching to 3.55s
Old Jun 12, 2012 | 01:00 PM
Mr.4spd's Avatar
I looked up your cam specs, pretty serious for a 383, you're not running the stock converter I presume. I'm still thinking Holley 750 DP, it fits the theme I think you're going for which is a snotty fire breathing 383. You can always modulate the throttle input, but I doubt you'll have to.
Old Jun 12, 2012 | 06:34 PM
Archer's Avatar
Plymouth -
Agree with 4spd on the 750 DP, but here's something you can play with... (just be honest with your input)
http://www.holley.com/applications/C...bSelection.asp
Old Jun 12, 2012 | 07:02 PM
rickyr's Avatar
I would go with the 770 Street Avenger With the auto trans.
The Avengers are dry flowed and @ a true wet flow the 770 is about 750 cfm that is still a bit big but being a vacuum sec. it will only open as the engine demands.
It also has a life time warranty
Old Jun 12, 2012 | 07:03 PM
Mr.4spd's Avatar
That carb selector is awesome, Archer. I think it's more guidelines, though. I ran it for my application and I'm supposed to be using a 1050 cfm vacuum secondary. Hilarious. I use an 830 cfm DP and you'd swear it's fuel injected.
Old Jun 12, 2012 | 07:07 PM
rickyr's Avatar
I would not go by that selector, it is fun to play with, but not that acturate
do cubic. inch X max RPM diveded by 3456 = CFM
And then if it is a light car and a stick and low gear go dbl pump.
other wise go vacuum sec.
northcoasttip
Sep 26, 2011 11:23 PM
Nomadci
Jul 29, 2010 12:31 PM
TwistedWrenches
Feb 27, 2009 01:58 AM
Chevyboy_0
Apr 7, 2008 10:10 AM
dodgeaspenrookie
Feb 5, 2008 08:05 PM
