Compression Question
Old May 20, 2011 | 11:45 PM
Slice's Avatar
Almost finished with 500 stroker 6 pack build. I'm trying to decide what compression ratio to go with. The heads are eddy rpm's, the cam duration is .231/.239. From what I understand felpro gaskets can put me at 10.4:1 or 10.1:1.
Can someone tell me how much difference this will make and how risky it is running 10.4:1 with my setup??? It is mostly a street car and though I want power, I don't want to worry about overheating or detonation
Old May 21, 2011 | 05:23 PM
If it is set up properly it will be fine on pump premium . Have you figured the squish area, valve to piston clearances, etc. I'm guessing those cam figures are at .050 lift. Talk to your engine builder !!!
Old May 21, 2011 | 08:10 PM
mopar777's Avatar
compression
i run 11:1 on my 440 and its all street. doesnt load up too bad with the 4.56 in the rear end. but def shutting it off at trains and such.
makes for a wicked stoplight hero
440 aspen
Apr 6, 2014 09:49 PM
Altosax
Oct 7, 2011 04:59 PM
69POLARA383
Jul 16, 2011 07:36 PM
deadkelly
Jun 3, 2009 10:15 PM
raycer5
Feb 4, 2009 05:09 PM
