connecting rod & wristle pins
Old Mar 12, 2020 | 02:40 AM
jeepers creepers's Avatar
Hy guys , i'm on the process of rebuilding a 3d gen Hemi 5.7 L, had to buy two new connecting rods because of #7 and #8 spun bearing, tried to put the piston pin by myself by heating the con rod and putting the pins in the fridge, then i made a sort of jig to do the job but with no luck, so now pins have to be removed or moved in postition.
So, heating con rod eye with a propane torch, even if i have been constantly checking the temp with laser gun ,for some reason one of the two reached almost 700 F wich i believe be too much, i know that overheating could be a problem also, these rods are those called sintered fractured, do i have to throw them in the garbage now or they can be reused ? Thank you for your help
Old Mar 12, 2020 | 10:17 AM
Better to leave the wrist pin at room temp and just heat up the connecting rod. with the pin that cold it cools the rod too fast when trying to install the pin.
If you going to use it for a stock application i would say you could use it. and also if its still in good shape and has not cracks are what you did.
But if your going performance, Throw them away and go this way with it >>>> https://www.modernmusclextreme.com/c...tons-rods.aspx
Keep us posted...
Old Mar 13, 2020 | 03:34 AM
Keep us posted...
Thank you for your response, no performance, i want to keep it stock and as reliable as possible, i will not put pins in the freezer anymore, problem now is how to move pins...
Old Mar 13, 2020 | 06:47 AM
Have to be pressed out. Careful not to damage the pistons if your going to reuse them.
Bullet18
Jan 28, 2018 08:27 PM
stilllearning6
Sep 22, 2017 07:08 AM
hmadic
Mar 14, 2009 04:20 PM
68coronet
Sep 25, 2008 04:06 PM
unclemike
Oct 11, 2007 06:31 PM
