Crankcase Evacuation System
Old Feb 14, 2025 | 04:58 PM
RBLowbucks's Avatar
My car has been apart for the past couple of years (no I didn't loose interest, had some medical issues) and now just starting to put it back together. I considered welding tubes in the collectors for a crankcase evacuation system, but I don't remember how much room there is around the collectors when it's all put back together. Car has a big block with TTI headers. These systems are supposed to be mounted on top of the collectors so the check valve will work correctly, but I'm not sure there will be enough room. Anyone have a similar B body build with one of these systems on it? Is there any room to spare?
Old Feb 15, 2025 | 09:24 AM
Street Car or Race Car?????
Old Feb 15, 2025 | 02:25 PM
RBLowbucks's Avatar
Race car with an occasional trip to a local car cruise when the hoses will disconnected at the breathers and plugged.
Old Feb 15, 2025 | 09:30 PM
I’ve used the header evac system on the street with no problems whatsoever, the only problem you can run into is if you have a restricted exhaust system because at the point of back pressure you can’t have vacuum in the collector.
Old Feb 21, 2025 | 02:18 PM
You can weld the bung in the side of the collector... Install as directed... At the 4 pipes before the collector... You can leave it hooked up for your street drive.... Similar to what Iowin stated, Check the check valves during routine maintenance.
Mark Ostrom
Dec 12, 2018 08:36 PM
LUVMYGTX
Aug 7, 2013 07:32 PM
Jwhis
Feb 4, 2013 12:39 PM
Mopar Rebel
Jan 13, 2010 07:56 AM
bgreene30
Sep 1, 2008 01:40 PM
