dayton dave
Old Feb 23, 2025 | 07:22 AM
DaytonDave's Avatar
dayton dave
have 73 360 in the dart. runs ok but timing mark is 180 out.has msd ignition .can only seem to get it to run with dist in this one position.just perplexed would appritiate any help thanks
Old Feb 23, 2025 | 12:42 PM
Kuvasz101's Avatar
I guess we'll start from scratch. The distributor only goes in 2 ways with a slot on the bottom. It will not run 180 off. You're placing your timing light conductor clamp on the first wire (spark plug) closest to the battery on the driver's side. If using a timing light that has advance for total timing, place it on zero and first set the timing to factory specs. Total advance timing at 2000=2500 rpms should be around 34 degrees.
DarrellW
Oct 6, 2017 02:42 PM
atodr95
May 28, 2014 06:41 AM
73'DartKid
Jul 11, 2012 01:06 PM
a.johansson84
May 27, 2012 03:30 AM
gotdust
Jun 6, 2011 11:44 PM
