Dodge 440 Sound - Something isn’t quite right
Old Jun 2, 2023 | 04:35 PM
70Challenger440's Avatar
Hi All -
suggestions welcome as the next step is to drop the oil pan.
I have a 70 Challenger w/440. New noise! When running, I hear a constant pffft, pffft, pffft.
thoughts?
thx
Old Jun 2, 2023 | 08:40 PM
Don’t overlook the exhaust…I’ve seen exhaust leaks, make the damnedest noises.
Old Jun 3, 2023 | 04:25 AM
Sound is up front right at engine level
Thank you for your insight. Any ideas about sound coming from engine? It’s right on top at front.
Dodge 440
Old Jun 3, 2023 | 04:44 AM
Kuvasz101's Avatar
Fuel pump makes that sound and is located in the front right of the motor. Mine was making noise but it was a knocking/tapping sound. I changed it with a new one and it was 10 times louder. I put the old one back in.
Old Jun 4, 2023 | 07:22 AM
It’s not uncommon for a big block to need a fuel pump pushrod, they rarely get replaced with a engine rebuild but after fifty plus years they tend to get shorter…
Old Jun 4, 2023 | 08:22 AM
Only time I pull the pan is when it goes Chitty Chitty Bang Bang,,,,, But Pffft Pffft Pffft... Not going to pull it for that.
Now if you can't find the source, Pull the whole engine and put it on a run stand and determine the problem.
Hope its something simple, Check for a loose Spark Plug....
Old Jun 4, 2023 | 08:25 AM
Hahahahaahahaha, I know something else that gets shorter after 50 years, and gets covered with a tool shed.... Cheers...
Doug Nelson
Nov 2, 2020 08:48 AM
seewavedr
Dec 10, 2016 06:26 AM
chuck1934
Mar 5, 2013 01:23 PM
44069roadrunner
Mar 29, 2012 08:53 PM
dodge6890
Jul 23, 2011 01:11 PM
