early 70s 440 water cross over
Old Aug 10, 2022 | 07:39 AM
oldschooliron's Avatar
Question early 70s 440 water cross over block off and what is this tube for?
Hi all - I have a 70s 440 in our motorhome, redoing the intake gasket (dead rat) - anyway, can i block off the hot water crossover between heads? Also - there is a weird water pipe with coolant going from under carb to water pump (bypass?) - can I also plug this off?
No need for heated manifold in southern california! If anything ill put on an insulated gasket under the carb-
motor is a 440 stock in a 27ft 1967 travco 270-
thanks!
Old Aug 10, 2022 | 09:14 AM
For around here... You can plug it off.... Just make sure the Electric Choke works and you shouldn't have any issues...
Mopar On !!!
Old Aug 10, 2022 | 09:28 AM
cool - yeah carb running good - what about the hot water cross over between heads? any chance i can block those off too? chevys have those block off plate shims that come in some kits..
Mopar On !!!
Old Aug 10, 2022 | 10:27 AM
We plug them off in Iowa, but then I can’t think of one 440 that gets lit at -20 not one.
Old Aug 11, 2022 | 04:17 PM
If your referring to the cross over holes in the middle of the intake manifold.... Yes you can block those off... Those should be just exhaust crossover's... Don't need those for around here nether..
And as you said... Use a good thick carb to intake gasket... The thickest you can get the better...
Old Aug 25, 2022 | 08:04 AM
gotcha thanks - since we might take the MH into altitude i just put it back on as it was- thanks for all the replies!
Old Aug 26, 2022 | 10:25 AM
Safe Travels... Keep us posted on how it runs... Mopar On !!!!!
Old Aug 26, 2022 | 10:26 AM
will do - prob try get her running this week cos we gotta move our shop
Old Aug 26, 2022 | 10:38 AM
I Hate Moving !!!! Again, Safe Travels... Best of luck on the moving... Cheers
Old Sep 3, 2022 | 08:26 AM
yep- had a deal fall thru to purchase and im sitting with 4 boats, rv, about 10 engines and a TON of equipment and nowhere to go as yet- lovely! Waiting for the Lord to open a door otherwise I might have to close shop and call the scrap guy!
clarqs
Mar 9, 2023 02:57 PM
windsor56
Mar 14, 2018 05:25 AM
crappace
Jun 29, 2014 11:48 PM
auerdoan
Jan 16, 2012 12:01 PM
Fratzog440
Feb 11, 2011 04:55 PM
