Edelbrock Cam?
Old Feb 20, 2012 | 01:59 PM
jake's rt's Avatar
Edelbrock Cam?
I am looking at purchasing the Edelbrock 2087 top end kit for my 440. My big question was this cam? The cam is Edelbrock 7194.
Cam StyleHydraulic flat tappetBasic Operating RPM Range1,500-6,500Intake Duration at 050 inch Lift238Exhaust Duration at 050 inch Lift246Duration at 050 inch Lift238 int./246 exh.Advertised Intake Duration300Advertised Exhaust Duration308Advertised Duration300 int./308 exh.Intake Valve Lift with Factory Rocker Arm Ratio0.480 in.Exhaust Valve Lift with Factory Rocker Arm Ratio0.495 in.Valve Lift with Factory Rocker Arm Ratio0.480 int./0.495 exh.Lobe Separation (degrees)110
I was wonder if anyone has this cam/kit? Can someone tell me how rough of an idle this will be. This is just a weekend warrior. Drive it to cruises and to the strip.
Old Feb 20, 2012 | 04:50 PM
We need more info.. such as
Gears
Compression
Trans
Vehicle
Old Feb 20, 2012 | 08:50 PM
jake's rt's Avatar
Right now it is just the block. I am considering that kit to help in building it. It is going in a Dakota with the 727 tranny. I was just curious as to how street or strip that cam is?
Jesse
Nov 13, 2011 05:35 PM
acoustictaddy
Jan 1, 2010 03:33 PM
TwistedWrenches
Feb 25, 2009 04:00 PM
Liu Kang
Jan 25, 2009 05:50 PM
General pavelka
Sep 23, 2007 04:31 PM
