Engine swap
Old Sep 10, 2020 | 02:07 AM
Madmax66's Avatar
Engine swap info on 225 L6
Hello, I just bought a 66’ Belvedere with the original 225 L6 in it. The engine needs some work to it and I was wondering if I should just rebuild it or if I should swap it for another engine? And if I swap the engine out, what would be a good engine to put in it? Thanks for the help.
Old Sep 10, 2020 | 04:57 AM
Archer's Avatar
MM -
Rebuilding the 225 would be the easiest route, and you would keep the originality of the car.
Besides being less expensive, it might increase the valve, if all the numbers match.
A "bigger" motor would certainly be more fun, but you'd be looking at a transmission change (possibly), motor mounts, maybe K frame and suspension down the road.
A 360 crate motor might be the easiest route, but depending on your budget, the sky is the limit. Either way you will be opening a can or worms.
You really didn't give us enough info on the current condition of the car what you want on doing with it.
bigmoss
Mar 25, 2019 07:17 AM
BigT92
Mar 29, 2013 02:29 AM
Shannon
Mar 3, 2013 08:19 PM
Shannon
Mar 2, 2013 01:27 PM
Daytona45
Jan 24, 2009 04:18 PM
