Engine swop info on a 273 Barracuda.
Old Oct 6, 2019 | 06:00 AM
Barracuda1967's Avatar
Worn 273 Engine.
Hello Mopar people.
Thank you for letting me join your forum.
I really need some help with my worn engine.
I have a 1967 Barracuda with a 273 engine, (not numbers matching)
I have took the engine out of my car because it was smoking on start up. Well upon inspection It appears the engine needs a complete rebuild.
It might be better to fit a crate 360.
Is a 360 engine physically the same size as my 273, would it drop straight in.
My Trans is a 904.
Many Thanks
Mark.
Mark.
Old Oct 6, 2019 | 08:01 AM
360 will fit and should not be a problem.... With that said, It is not just a direct swap. But i dont remember all that was needed to make the swap. But its not to painful as I remember.... Keep us posted and Welcome to the site.
Old Oct 6, 2019 | 08:10 AM
Welcome to the forum.
I believe the motor mount bracket on the drivers side is different on the 360. Other than that you will need a flexplate for a 360 but it will bolt to the 904. Headers, radiator and maybe a transmission upgrade might be needed.
Old Oct 6, 2019 | 11:24 AM
heck, dare to be different and rebuild that 273! bore it, put a nice thumper cam in and do the ports/valves on the heads. it'll be a little screamer!
Old Oct 6, 2019 | 12:30 PM
Drag Pak's Avatar
You will need to either purchase these as a set
https://www.engine-swaps.com/Pages/P...its.html#head1
or make your own!
https://www.google.com/search?rlz=1C...G40trdgIMmecM:
Or. like mentioned build the 273 into a zinger!
Old Oct 6, 2019 | 12:42 PM
Thanks for your reply Bob
I keep googling for more information
In quite new to Mopars thesis my first one
parts are hard to get as I'm in the Uk.
Old Oct 6, 2019 | 12:45 PM
Thanks for your reply Iowan
I read the 360 is externally balanced
Do I only need the flex plate to make it balanced again, the flex plate with the half moon shape cut out.
Old Oct 6, 2019 | 12:53 PM
Hi Skwerly
Thanks for your reply.
I would love to - but I think it needs to much doing to it.
HEADS
The valve seats are worn/sunk I would need new seats.
The valve stem guide are oval - so they would need machining and bushes fitted.
ENGINE
The bores are worn and one of them has 2 score marks - could be a broken piston ring. ?
I haven't stripped the block down yet to check the crank bearings etc.
Are parts still available to rebuild it
Its a bit difficult to get parts because Im in the UK - but I could get them shipped to me.
Old Oct 6, 2019 | 12:55 PM
Thanks for the reply,
The information you passed on is great.
I could make the new engine mount.
Old Oct 6, 2019 | 12:58 PM
New 360 engine.
Thanks in advance
Where would the best place to get a 360 engine.
Old Oct 6, 2019 | 01:53 PM
That Does make it a challenge being in the UK... If you don't have a resource then yes you have to import the stuff.... Ouch.... Blue Print Engines..... https://blueprintengines.com/ is a good one. if you do not have any one in the UK to source and build you a engine. But I thought I had seen a few guys building stuff over there?????
However it might be easier to check with the guys in Italy and see if it may be cheaper to ship you one?
http://www.2000motors.it/index.php/it/
Yes you have to make sure you get all the matching parts for a 360 build. You can Google that info. But that would really make that Cuda fly...
Old Oct 7, 2019 | 01:02 PM
Hi Bob.
We have got some engine builders in the uk.
But I was just seeing what was out there.
Thanks for your comments.
‘I’ll keep looking.
Im just a bit hesitant about fitting a 360.
My 1967 barracuda has a later 73 k frame and later engine mounts.
Old Oct 8, 2019 | 07:20 AM
318 Build would be good also.
Keep us posted on what you decided to do with it.... Mopar on Brother....
Old Oct 12, 2019 | 04:42 PM
I've been reading on the 273 for other reasons and it appears that there's not much for pistons available, only one or two suppliers. The 273 has a following but if it's not original to the car I'd replace it with a 318 or 360 in a heartbeat. 🙂
sammywhiteass
Cuda Specific Discussion
21
Mar 25, 2012 01:42 PM
johnzdad
Sep 19, 2011 06:17 PM
tracktor312
Nov 3, 2010 08:00 PM
Tech Talk of the Month
Jul 11, 2010 10:37 AM
fpereira23
Sep 10, 2008 01:21 AM
