Engine Tap
Old Apr 30, 2014 | 05:57 AM
ChristineIII's Avatar
Engine Tap
Christine is a Fury III, 1968, 318. Just recently she started tapping. Plenty of oil and it feels and looks normal. Should I be considering new oil pump? Im not sure when the current one was installed. I havent had any valves, etc. adjusted as long as Iv had her (1.5 yr).
Old Apr 30, 2014 | 08:19 AM
pro-tech's Avatar
What is the oil pressure?? Marvel Mystery oil works wonders on sticky lifters...Bill
Old Apr 30, 2014 | 01:06 PM
68 has hydorolic lifters no adjustment needed or required
Old May 4, 2014 | 07:44 AM
Thanks folks for the replies. I put a whole can of Seafoam into the oil and ran the engine until hot. The tap didnt take long to go away. Obviously an oil change has been done to rid the Seafoam. Im a huge fan of Seafoam in moderation.
Old May 4, 2014 | 12:45 PM
pro-tech's Avatar
Great news and A great product I use the injector cleaner quite often.. Glad it was an easy fix...Bill
Old May 4, 2014 | 10:26 PM
With today's ethanol gas you need to use it on a regular basis. If for nothing else , to get rid of the water
ProEmaster
Jun 6, 2007 11:31 AM
