external oil lines for a stroker?
Old Aug 27, 2013 | 02:24 AM
Seanzie1405's Avatar
Does anyone have any experience working with external oil systems just something i've been curious about sense I read that 440 source has 543 stroker kit and it requires an external oil source set up? how would some thing like that be set up? also if you ran forced induction like a turbo how would you run the oil return? I don't have any experience with external oil lines and etc so if anyone has any experience with them any info would be great
Old Aug 27, 2013 | 05:17 AM
Get the swinging pickup from 440 Source, go to Summit Racing and buy the Milodon external pump set up. Get some braided line and some AN fittings. I also used a Deep sump pan that already had the hole for the pickup.
Old Aug 27, 2013 | 12:09 PM
moe7404's Avatar
the oil return line into the pan should be above the oil line. if you return the oil below top of the oil the return line will jam up and over flow.
koterkid
May 26, 2013 09:49 AM
murry
Apr 14, 2011 04:16 AM
69POLARA383
Oct 9, 2010 06:03 AM
fastdakota84
Jun 17, 2009 01:54 PM
dzltd02
Oct 28, 2008 08:25 AM
