Fan Clutch
Old May 16, 2014 | 10:27 AM
demetri's Avatar
Fan Clutch
I was told that when the car is hot, and you turn it off, a way to check the status of the fan clutch is to spin it by hand. A properly working fan clutch on a 440 should barely spin by itself.
Is this right? If not, what is a proper way of testing the fan clutch?
Thanks
Old May 16, 2014 | 03:08 PM
This is what I found:
If you can't spin it by hand when the engine is off then you need a new clutch
If you can spin it by hand with the engine off and it spins for a long time then it is also bad
If you spin it and it spins for 1 or 2 revolutions then it is ok
Old May 20, 2014 | 08:12 AM
It should have resistance to turning when hot if it's a thermal clutch. Some are not a thermal clutch and spin more free at higher rpms.
Old May 20, 2014 | 10:47 AM
Check Step #9...
Cazbah362
Jun 12, 2011 01:05 AM
mytracy
Dec 29, 2010 08:20 PM
carl
Sep 2, 2010 09:15 AM
bigbadsrt
Mar 21, 2008 09:32 AM
gotdust
Jan 31, 2008 02:32 PM
